DynMetalworks
I have a old press brake that I want to retrofit a PLC to with a linear encoder on the Y axis and a stepper motor on X axis.
Y Axis: I would have a home switch at the top of the travel that I could jog the ram up to then zero the encoder on the PLC. I could then enter in the PLC at what distance I want it to output a signal to activate a solenoid to change the hydraulics from fast to slow. Then another distance that it sends a signal to active a solenoid to stop the ram movement.
X Axis: I enter in a dimension and it moves the stepper motor to that distance. This part seems pretty easy once I know my steps and lead screw ratio.
I'm not sure what PLC would work for this? I've attached a picture from a manufacture who has a PLC on their shop press brake that controls the Y axis. This is exactly what I'm wanting with the addition of the X axis.
