plc hmi
chetwood
Oct 2010
ma
looking for 17 inch or larger touch screen to work with allen bradley compact plc. replace a 1000 plus unit or c-more screen
Any reason for a "TOUCHSCREEN" that large? There are several HMI packages that will run on a PC. You can get as large as you want.
pc yes,but I looking for one to work with plc.
to replace a standard a.b. 1000plus or a c-more automation direct to work with a ab compact plc.
most plc hmi are 15" max
Have you ever seem noticed the screen at McDonalds, or any other resteraunt? They are touchscreens
The PC route is all I know to get you a large screen. You could use a Redlion G3 and enable the web browser and use a computer as the front end.
Do you need a "TOUCHSCREEN" or display?
If you want to go down the televison route then i can vouch for Elo Touch
Used 9 off 26" samsung elotouch's on a job 2 weeks ago
53
73
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
97
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
156
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
142
