PLC Knight Rider programme.
gnccollege
Nov 2013
UK
Hi Guys.
Im Programming a knightrider beam light using GX Developer on 8 leds flashing from Y0 to Y7 and back.
Anybody know how to do that?
i have done half the programme where leds are flashing from Y0 to Y7 but i dont know how to go back from Y7 to Y0. the programme also has to run forever until switched off.
I have started with T0 with Y0 as output and timer of T0 K5 and then i closed the loop with T0. this turn on Y0 for 0.5 second and move on to next output. i have done all my steps same like this. I just dont know how to go back from Y7 to Y0.
Pls give clear instructions as im new to plc.
Ron.
Thanx for the reply shooter.
could u pls tell step by step.
my programme looks like this.
X0 T0 Y0
! T0 K5
T0 T1 Y1
! T1 K5
and so on.............
----X0--------T0-----------Y0
---------!----------------T0 K5
----T0--------T1-----------Y1
---------!----------------T1 K5
Knight Rider
I'm assuming you want single LED lit, going left to right, then back, then recurring. If last timer initiates first it will cycle. Close x0 to trigger all cycling. Each LED has two conditions to trigger it. Shifting or numeric comparisons will allow a tighter program to achieve same then shown below.
| .. X0 ..TIM 4 ...............TIM 001/0.5 sec
|---| |---|/|---------------------( )-----------| Initiate timer for leftmost light. Close x0 to initiate sequence.
| .. x0 ..TIM 001 .................Y0
|---| |---|/|---------------------( )-----------| Fire leftmost light
| .. x0 TIM 001 ..............TIM 002/0.5 sec
|---| |---| |---------------------( )-----------| Initiate timer for middle light
| .. x0 . TIM 001 .. TIM 002 ......Y1
|---| |-+-| |----------|/|-----+--( )-----------| Fire middle light
| | TIM 003 .... TIM 004 |
| . x0 . TIM 002 ............TIM 003/0.5 sec
|---| |---| |---------------------( )-----------| Initiate timer for rightmost light
| . x0 . TIM 002 ....TIM 003 ..... Y2
|---| |---| |----------|/|--------( )-----------| Fire rightmost light
| . x0 . TIM 003 ............TIM 004/0.5 sec
Thanks for ur reply FSEIPEL.
im just using plc for the 1st time.
the sequence u told me, will it turn on all lights from Y0 to Y7 and back?
Could u tell me the 1st step for this programme so i can carry on.
and step to come back from y7 please?
thanks
Convert program below to ladder ("Ladder/Instruction View switch" button). It is tested:
0 LD>= D0 K15
5 MOV K0 D0
10 LD X000
11 ANI T1
12 OUT T1 K5
15 LDP T1
17 INC D0
20 LD X000
21 LD= D0 K0
26 OR= D0 K15
31 ANB
32 OUT Y000
33 LD X000
34 LD= D0 K1
39 OR= D0 K14
44 ANB
45 OUT Y001
46 LD X000
47 LD= D0 K2
52 OR= D0 K13
57 ANB
58 OUT Y002
59 LD X000
60 LD= D0 K3
65 OR= D0 K12
70 ANB
71 OUT Y003
72 LD X000
73 LD= D0 K4
78 OR= D0 K11
83 ANB
84 OUT Y004
85 LD X000
86 LD= D0 K5
91 OR= D0 K10
96 ANB
97 OUT Y005
98 LD X000
99 LD= D0 K6
104 OR= D0 K9
109 ANB
110 OUT Y006
111 LD X000
112 LD= D0 K7
117 OR= D0 K8
122 ANB
123 OUT Y007
124 END
Best regards,
Vuckovic Goran.
1. Copy it to text file,
2. then Project->Import file->Import from Text, CSV format file,
3. Then Alt+F1 to convert to Ladder...
I don't know GX Developer at all, so can't help with the programming.
However, before you get fully developed for a single LED going left to right, then back, I don't believe that KIT's lights were like that. I think they were "waved" across, like in the picture I've attached.
I've shown examples for 2, 3, 4, and 5 LEDs
If you are after realism, you might find one of these patterns better, and it might shape how you do your logic.
In Allen-Bradley, I would achieve these patterns using an instruction called "Sequencer Output", or SQO, and could do any of these light patterns in an Allen-Bradley PLC using only 2 instructions !! Perhaps there's a similar instruction in GX ?? IDK...
oops forgot to attach the pic...
Gnccollege,
Don't be lazy, you can always do it with you keyboard. Find bellow printscreen.
Best regards,
Vuckovic Goran.
goghie
can i ask which gx developer version r u using?
GX IEC Developer
GX IEC Developer FX
GX Developer
GX Developer FX
I prefer GX IEC Developer (it is much much better - two light years in front comparing with GX Developer), but for this occasion, I have used GX Developer 8.101F, as you wrote that you are using it....
189
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
186
40
Hi All, Someone at work has put a PLC system on my desk, that's just been taken off an idle production line. He said "It's an S7 PLC. We don't...
250
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
