ExtremeIntegrations
OP
This is good information, thanks. I do have the FP-X C14R. I bought the small 8 port just to keep it simple to learn with. You are correct that support seems to be hard to come by. Since I'm a contractor to this company I must succeed in this project so I'm guessing there are many late nights ahead
I think the most difficult part is learning the development environment and understanding what I'm looking at and each part. For example I've been at this for 3 days and I have NO idea what POU even means.
My client is pretty cheap so cost was the factor that drove us to the Panasonic. I think if I can start to understand the workings of the PLC then I should be able to catch on quickly and make this happen.
Most lower-end PLCs don't have multithreading capability; the entire program is repeatedly scanned over and over. But since the processor is so fast, this is generally not a problem unless you have a very large program and/or complex math. Many PLCs have interrupt capability that allows you to execute specific code more frequently if necessary.
I do have some experience with the Panasonic/Matsushita PLCs. The FP-X series in my case. These are very capable units but the FPWIN software does take a little getting used to. Have you gone through the First Steps Demo? I have found the online help to be fairly thorough. The structured text commands are all documented there, but not organized well. The AFPX-C14R on my bench is running a fairly small program with a scan time of <1 ms (not bad). If you add your POU's to the "Programs" task in FPWIN, they will scan repeatedly as fast as possible. Look in the PLC Status window (Monitor menu) while online with the PLC and you can see the current scan time.
If you're just getting started with PLCs, I wouldn't recommend the Panasonic. It's a powerful unit to be sure, but you won't get much support from online sources (like this website). Choose Allen-Bradley, Siemens, or Automation Direct and you'll get much more help -- assuming you ask the right questions
