Plc Output devices. solenoid and a solidstate device.
Rpowelll
Jan 2015
Newcastle
Hi, ive recently just started studying Plcs as a topic within my engineering course. and im finding it extremely hard to find information about these 2 questions given to me by my tutor. so if you would be so helpful to share any knowledge you can help me with it would be appreciated.
I need to be able to explain the construction and the operation of a 24v dc solenoid with a stroke length of 20mm. and how it is interfaced to aplc?
A solid state device for switching a 240v 10A ac load?
and the construction and application of opto-isolators in plcs?
if some one could shine some light on me for this, please as i am really struggling to find some straight forward answers online.
Most PLC digital inputs use optical isolation to protect the PLC from voltage spikes or improper wiring. The input comes in and turns on a little LED and a receiver sees the light from this LED and tells the PLC the input is on. All of this is inside the IO module.
High speed inputs don't have time for optical isolation, and so try to use other methods, like fusing to protect the PLC.
VDRs (Voltage dependent resistors) are another way to protect the IO from voltage spikes. High voltage causes the resistance to drop to nearly nothing and shunt the current to ground.
What, Light is slower than electricity?
Switching times for LED and Optical pickup are, which is why VDRs tied to ground are getting very popular. I actually looked at a spec sheet for IO that I know used to use optical isolation and they've switched over to VDRs, and raised the maximum switching frequency. It may be that optical isolation is on the way out?
What i'm trying to grasp is what does the stroke length of the solenoid have to do with it? If you are caring about reaction time never use a mechanical relay. On the same note I strongly reccomend against ever using your PLC's outputs as relays for solenoids. Just my 2-bits
The solenoid stroke length would control the type and size of equipment that could be operated with that solenoid. The solenoid stroke length has to match the required stroke length of the valve, pusher, brake, switch, and so on (the equipment to be operated).
Im currently studying about plcs and I was wondering if some one could shine some light and help me with these as I cannot find much information...
2,711
Hi, I'm trying to research a few input and output devices for a PLC. I've managed to find a couple of Input devices, such "XUJ Thru beam and...
3,870
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
123
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
246
Hello, the PLC in question is 1769-L30ER. I have a local 4-20mA Analog Output module (1769-OF4CI), and also a remote ethernet PointIO analog...
406
