write the Boolean expression and draw the gate logic diagram and typical PLC ladder logic diagram for a control system wherein a fan is to run only when all of the following conditions are met:
*input A is off
*input B is On or input C is On, or both B and C are on
*inputs D and E are both On
*One or more of inputs F,G or H are On.
Draw the framework for a ladder diagram, then start from the output and work your way towards the inputs according to the logic.
*Note, the example below is random. The "inputs" are not to demonstrate your problem*
