PLC S5 hardware config, replacing card...
userxyz
May 2002
any
2,768
This afternoon I have to replace an inputcard in an S5 rack. Slot 0 now has an input card, I need te replace it by an 16 in/out card. But what about the adresses, what adresses will I have, can I find this in some manual ?
Thanks,
Kind regards,
Combo
Perhaps you should Post the Model Number of the old Input Card, and the new Combo Card. I don't have S5 on the PC, but I would assume the Inputs would be the same Addresses. However, you know what they say about assumptions.
Stu.....
If I remember correctly, the 95U has 'place-oriented addressing'.
I think it was a multiple of 4 bytes.
The first card is I/QB 0, second card I/QB 4 a.s.o.
Your new card will have the same byte number on the IB and QB as the old input card.
B.t.w. How are the existing adressing arranged?
With a grain of salt
Kalle
In/out
Cards:
6ES5-95-8MA11 (S595U CPU)
Replacing
INPUTCARD:
6ES5-421-8MA12
by:
IN/OUT CARD:
6ES5 482-8MA13
A guy from Siemens told me that the adress range of IN/OUT cards is different ?
Regards,
C
Kalle
Slot assigned adressing.
Slot 0 : Inputs 64-65, Outputs 64-65
Slot 1 : Inputs 72-73, Outputs 72-73
Slot 2 : Inputs 80-81, Outputs 80-81
Onboard IO is 32-33
It is not.
I checked.
Else I'm missing something.
Had to check our old systems to find out the adressing.
Hi, Please I am new to Siemens Step 7 Simatic manager. I have a system with s7 300 cpu which has a profibus interface module IM 153-2. Inside the...
2,745
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
154
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
579
Hello, Here i have a Tia Portal V11 Project that i wanted to fix but i cant take the device configurations from the device. So i just have to...
1,473
I have next-to-no experience with PLC programming. I am a C programmer, and have an application (in C) running on control PC which needs to get...
40
13,326
