Uploading Hardware Configuration From PLC
thewalkerist
May 2021
Izmir
178
Hello,
Here i have a Tia Portal V11 Project that i wanted to fix but i cant take the device configurations from the device. So i just have to mess around and see what is right and wrong by trial and error. I fixed the inputs and outputs but now i believe there is a problem with data blocks or smthng. I cant just transport the entire hardware config. Now i see something like this screenshot i posted.
See that red functions? They all have one thing in common. That DB2..... stuff. Now i believe there is a problem with optimized block access or smthng like that.
But i have no idea how to fix this.
Any ideas?
It cannot be optimized block access. In that case you would not see the absolute address DB2.DBW0
Odd, i would guess that TIA would catch a faulty program when compiling, and also refuse to transfer a program with errors.
Your TIA is VERY old. I would seriously consider upgrading to a newer version. There are a lot of bug fixes, and also better functionality overall. IMO V11 was barely functional.
It is possible that what you see is fixed in a later version.
I think the explanation is that DB2 is non-optimized, and DB2.DBW0 does not contain a word-sized variable.
That is why there is a warning, but not an error.
This can work if the original programmer intended it to work in this way.
Yeah, normally i am using v16 but this is a old project and until i get everything right and same as the device i cant upgrade it
Hi all, I've got a strange problem on one of our old S7-315's. There are no error LEDs on the PLC and it runs fine. I have a project on our...
9,476
Has anybody uploaded a Siemens S7 hardware configuration ( because you don't have the program) then downloaded again after making a change( for...
2,121
Hello, I face with a problem when I try to getting online to CPU 315-2dp (315-2ag10-0ab0-V2.0.8) using Step7 V5.4. I can upload...
3,553
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
136
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
302
