Uploading S7 Hardware Config
SteveJDRG
Jul 2015
Perth
Has anybody uploaded a Siemens S7 hardware configuration ( because you don't have the program) then downloaded again after making a change( for example adding a network card) when you don't have all the gsd files on your laptop for the slaves already configured, and then seen any problems ? Do you need the GSD files or is the fact that the correct configuration has been downloaded once enough ?
Cheers
Steve
Not sure its something I would do unless I really really had to.
How do you fault find etc after you made a change?
If it doesn't work then you may have a problem.
Certainly if I did this, I would ensure I had two copies of the program, one the original in case I had to reload it.
I would look very hard for a legit offline copy first
I dont know exactly if you can upload the full HW config including eventual GSD files. I have never tried it myself. I am always working with the original program.
But you can check the uploaded HW config by inspecting it manually.
Are all eventual Profibus or Profinet devices present ?
If yes, and when you save and compile everything there are no errors you should be good to go.
Hello, Here i have a Tia Portal V11 Project that i wanted to fix but i cant take the device configurations from the device. So i just have to...
1,476
Hi all, I've got a strange problem on one of our old S7-315's. There are no error LEDs on the PLC and it runs fine. I have a project on our...
9,478
Hello, I face with a problem when I try to getting online to CPU 315-2dp (315-2ag10-0ab0-V2.0.8) using Step7 V5.4. I can upload...
3,554
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
136
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
304
