PLC Schneider Momentum M1 behavior of ethernet remote outputs during network outage
VDohnal
Aug 2014
Liberec
This question is about PLC Schneider Momentum M1 171 CCC IEC-960-30.
We have one output element ADO 710 50 attached to the PLC via 170ENT11002. This element is in Concept Configurator mapped to a specific address (40203) for Write.
Setting for Read for this element is "Set to 0" (not "Keep last value") - but I suppose it is not used, since it is digital output element so PLC reads no bites from it.
When there is interruption of network communication between 170ENT11002 and Momentum PLC, does the state of the digital outputs in ADO 710 50 remains the same as it was during the last successful cycle or is it reset to 0?
(There was sudden stop of 2 (of 7) machines attached to the element, but I doubt it was caused by the PLC system)
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
159
Dear Friends, This time I have been assigned a project, where machine has Schneider Momentum 171CCC78010, 171CCS7600 installed. I don't have...
2,702
Hi..I am working on a project involving Momentum PLC 171CCC98030. I am doing its programming in Concept 2.6 SR7 (Demo Version) . I have following...
1,825
I have a customer that would like to move away from Wonderware to RSlogix5000. They currently have Schneider TSX PLCs at their location and would...
2,486
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
