plc supporting ascii communication
arclivin
Dec 2013
doha
18
<P>please suggest a cheapest siemens/schneider plc that supports ascii communication with third party controllers using rs232 port and also has modbus rtu connectivity also</P>
A CPU with 2 RS232 interfaces?
The cheapest Siemens variant is probably a 1200 with 2 serial cards. Must be programmed with TIA.
My choice would be an S7151-8 with one ASCII card 6es7138-4df01 and one Modbus card 6es7138-4df11.
Edit: You might find a cheaper combination here : www.vipa.com
Kalle
Just remember that you will need the programming environment to. So a cheap solution from Siemens, might turn into a not so cheap solution if you only have a single project.
Hi, I have a project in which I need to communicate with FMC Sybertrol flow computer in modbus RTU. The flow computer has a whole range of...
2,736
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
53
Hi, hope you doing well I am looking for SIEMENS PLCSIM equivalent in GE FANUC PLC, RX3i PLC thank you
20
Hai, I'm working on Allen Bradely PLC RS Logix 5000 V20 i tried to communicate modbus communication with AB plc and RS 232 to Ethernet converter...
46
Trying to learn PLCs going to start by buying an Arduino Opta Wifi to practice with but what's the PLC I should get next?
250
