plc supporting ascii communication
arclivin
Dec 2013
doha
18
<P>please suggest a cheapest siemens/schneider plc that supports ascii communication with third party controllers using rs232 port and also has modbus rtu connectivity also</P>
A CPU with 2 RS232 interfaces?
The cheapest Siemens variant is probably a 1200 with 2 serial cards. Must be programmed with TIA.
My choice would be an S7151-8 with one ASCII card 6es7138-4df01 and one Modbus card 6es7138-4df11.
Edit: You might find a cheaper combination here : www.vipa.com
Kalle
Just remember that you will need the programming environment to. So a cheap solution from Siemens, might turn into a not so cheap solution if you only have a single project.
Hi, I have a project in which I need to communicate with FMC Sybertrol flow computer in modbus RTU. The flow computer has a whole range of...
2,740
Hello, I want to connect the Factorytalkview ME with rslogix500 to see the live response of HMI buttons in Rslogix500 ladder code . I am using PLC...
52
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
99
Hi, hope you doing well I am looking for SIEMENS PLCSIM equivalent in GE FANUC PLC, RX3i PLC thank you
38
Hai, I'm working on Allen Bradely PLC RS Logix 5000 V20 i tried to communicate modbus communication with AB plc and RS 232 to Ethernet converter...
61
