PLC tasks needed!
werder85
Dec 2007
Brasov
21
Does anzone know where I can find some PLC tasks (I don't know if the term is correct)? By task I mean a 'problem' which should have between 5 and 15 or 20 inputs and outputs and which should be solved by a PLC.
Thanks a lot.
Do a search for "homework" and you should find plenty of examples of systems that require that sort of input and output. Rememeber when counting IO that motors normally have at least 3 points associated with them - 2DI, 1DO (I1: contator closed feedback, I2: thermal overload healthy, O1: close contactor. Optionally, DI3: motor maintenance switch feedback). So you could easily make a conveyor system with 3 motors and some sensors that does something useful, for instance sorting packages by weight into different lanes, or a level and filtering application for a swimming pool, or anything you like really. Or a consider what might be needed to implement a controller for something like, say, a wind turbine. Think of almost any automated practical task that does not require very high speed control, light weight, enormous project size or some other specialty characteristic and a PLC can be applied usefully to the problem.
Thanks for your fast reply, but I'm really looking for tasks which have been formulated. I've already tried to write some tasks by myself but I'm not a specialist in mechanics, pneumatics or hydraulics. That's why I'm loking for tasks, especially for those who also have a drawing.
P.S. How do you say 'task' in german, I'd like to make a search also in german.
Curios on the thoughts of using Continuous vs Periodic tasks. . The old SLC-500's mostly only had Continuous tasks. . The Compact & Control...
49
13,966
We are building a small plant that packs beverage cans from a conveyor belt to a crate in responce to an order.I have been assigned a task to...
2,653
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
50
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
46
