Dayvieboy
This has been entertaining.
I totally agree, lots of great input!!
The key question here is what is the project? For a lot
(I'm going on a limb and say the majority)
of projects it won't matter much
Almost everything matters here
This project:
Only 2 PLC's
... 1st Prototype Ships In ~6 Years
... over 108,000 hours of PLC work (54 man years)
PLC guys here, for the most part
... do no wiring, cabling, chassis building, packaging, drawings I/O testing etc...
... Most time is spent on the program
... Though we do end up gowned up once in a while for sure.
7 Very Senior Level Programmers, 2 Very qualified (9 total)
... All well rounded PLC/SCADA/Database/Network guys
... ~215 years of combined experience
It has pretty much any & everything I have ever seen on a project
... 5 volt PLC I/O cards TTL level
... Sending & reading 10 ms communication pulses on remote Point I/O with required accuracy of +/-0.5 ms
... Many PID loops with mili degree accuracy required
Many protocols
... ASCII 232 & 485
... Modbus Serial
... Modbus TCP (using code in PLC without adding special Modbus module)
... EthernetI/P
... DeviceNet
... EtherCat on Allen Bradley (trying to nix that)
~15 remote chassis (panels)
... ~40 total racks (AENTR cards)
~2,000 physical I/O
~100,000 virtual I/O
... Vacuum Transmitters, Oxygen Transmitters, Getter Ion Pumps, Neg Pumps
... Turbo Pumps, Chillers, Heaters, Environmental Controllers, Robots, Servos
... PQube Power Monitors, Weather Monitors, Barometric Pressure, Lasers
... Many others
Trending in Ignition @ 250 ms default for many tags
... & higher for a few special tags
Sil2 Safety mostly, possibly Sil3 for a few components
... 3rd party will read every line of safety code & test it endlessly.
Must be safety stamped for nearly every place in the world
... Taiwain, Japan, Korea, Europe, US
Not only do they need to pass countries codes
... Every customer has requirements that are additional
... 1 machine must fill all safety & customer requirements
Remember with the Rockwell guys - those that can, do.
Those that can't go into sales and sometimes tech support.
I realize that I'm painting with a broad brush and there are some very notable exceptions -
apologies to them.
The local rep I asked this question actually gave my first
... & only PLC class over 30 years ago on a brick SLC 500
... He gave me good rational advice on this
... and he never talks in absolutes
... Good guy!
That is like asking a saw manufacturer how to best build a house.
Your response to my comment "I get various opinions when calling tech help"
... Quite accurate
The Engineers that I have a hard time tolerating are the ones that say:
... "I called Tech and they told me it must be done this way"
... or worse
... "They said it can't be done..."
Front line techs on the help line are generally either beginners or perpetual intermediates.
... As soon as they get some experience they move up the ladder
... and you only get to talk to them again when issue is escalated.
