I've inherited a L61 that was installed last year and the memory usage is well into the red. There is only one continuous task with a scan time of 8-9 ms and from what I can see, default rate on a continuous task is 10 ms so I don't have any room of communications which I believe is one of my issues with some of my tag communications in Ignition.
I read on the Inductive Automation forum that I should change the continuous task to a periodic task to improve my tag loading factor. Can the change from continuous to periodic be done while online?
Thanks for any shoves in the right direction.
Bob
Bob
