HMI Buttons go to error after changing screens
My wild guess is that there's another object on the screen (it would take just one) that addresses a non-existent data table file. When the PV+ changes to that screen, it tried to start polling that address and gets an error, but because it's a serial connection there's not enough "bandwidth" to accommodate the attempts, errors, retries, AND the normal connectivity. The whole optimized block comms falls apart.
Maybe when the co-worker re-addressed all of those objects they remedied a typo, maybe working too fast to realize it.
This kind of error *should* show up in the FactoryTalk Diagnostics display object, and/or in the FT diagnostics display window of FTView Studio if you test the runtime on your development PC.
Or, sunspots.
In support of Ken's wild guess, I just today dealt with a PVP where indicators on one screen were failing to update and the cause was indeed an object with a connection to a nonexistent tag. This was with an enet connection to a compactlogix, but somewhat similar symptoms. The diagnostic display pointed me right to the offender (once I increased the font size, the default on the PVP600 is something like 5pt apparently and quite illegible).
Hi Guys, what could cause HMI Button names in runtime to be showing 'text' instead of their real names. (TIA Portal - Comfort Panel)? I will...
1,665
Hi, I have to replace an old Exor Tline HMI with a siemens HMI. I was able to upload the project from the HMI but it appears to have not uploaded...
1,229
Hello, Controllogix 5572 with Studio 5000 v33 and FactoryTalk View SE v12. Is there a way to force I/O bits using HMI pushbuttons? I've tried...
2,897
Hello, When it comes to process control (e.g starting/pausing/stopping a batch or sanitation function) with HMI pushbuttons, what is the...
2,989
I am hoping someone can help me. I have a siemens system in our facility that was built by a 3rd party. It arrived in less than stellar...
21
10,449
