PLC to LED display (Andon) board communication
sundar_recr
May 2006
Coimbatore,Tamilnadu.
How to communicate a Production count display (Andon) board via Allen Bradley Compact logix PLC Through serial port. I need Port configuration, 9 pin 'D' connector wiring diagram. Please help.
Have you tried reading the Andon device manual to see what you need?
The A-B port pin-out is well documented.
What, specifically, are you having problems with ?
Hai All, In my application, the Micrologix 1400 for PLC and FactoryTalk View SE for SCADA Screens are used for Controlling and monitoring the...
2,654
Does anybody have an idea on how to display lights on an OLED sheet through a PLC?
1,722
Hy guys...i have a problem... i have a PLC (Twido) and a LED display in the plc program i have a counter wich will retain a predefined value in...
3,579
hello everybody, I need to be able to control the MTL serial text display http://www.mtl-inst.com/product/mtl646_647_indicators/ by a dedicated...
3,684
Our company used to use Modicon TSX Nano PLC. I am replacing with Twido PLC. For program conversion there is one problem that I can't figure out...
2,914
