PLC controlled serial text display
wulkhell
Jan 2010
Melbourne
hello everybody,
I need to be able to control the MTL serial text display http://www.mtl-inst.com/product/mtl646_647_indicators/ by a dedicated Modicon M340 PLC.
This is my first real-world PLC project, but ascii is something completely new to me. I've done some reading on ascii function with the rslogix (I only have access to rslogix for the moment), and still not sure about it. Can somebody in this forum check my codes, or suggest any better solutions?
For example:
<CS>
<WT example>
A -------------------------
---||---| AWT |
| | Channel 0 |
| | Source ST9:0 |
| | Control R6:0 |
| | String Len 0 |
| | Char Sent 0 |
| | Error 0 |
|-| AWT |
| Channel 0 |
| Source ST9:1 |
| Control R6:1 |
| String Len 0 |
| Char Sent 0 |
| Error 0 |
Define the following strings in data file ST9:
ST9:0="<CS>"
ST9:1="<WT example>"
Thanks in advance :geek:
My boss has come up with the idea of renting machines and charging on a per use / per hour basis, so I'm looking into it - just getting my feet...
3,996
I have an emco lathe I have retrofitted for a new control (mach4) and electronics. I have saved this turret for last because I knew it was going...
77
30,034
Need help with designing and test a PLC-controlled pneumatic system that conveys manufactured parts and loads them on a packing machine. I am...
2,673
Hi all! I can't seem to figure out what I'm doing wrong. I have wired up my stepper motor, control, and uploaded test programs and nothing...
1,864
Imagine, if you will, a series of custom built modules (building size). Each module is setup with standardized control/automation equipment...
5,648
