currently operating machine that is currently using a CJ1m-CPU22
this sends an analog output to FR-FC inputs on the drive then links the next drive from AM-AC to FR-FC on the nexct drive. We then modify the speed reference scale parameter so that when we enter a % of full speed the speed reference will generate a speed change of 20% from one drive to the next in order to maintain a 20% increase in speed from one conveyer to the next one. This worked out rather well so here is my question.
For one reason or another we replaced the first motor with a hydraulic motor. Now I want to remove the first drive in the panel and I'm concerned that the speed reference that the second drive will recieve from the PLC may be altered throwing off the speed reference scale. When the drives are wired in this configuration is ther any change in the output from the PLC as it passes thru one drive to the next? Or should it remain at the same voltage from one drive to the next. The only reason I would like to know is to know how much time I should set up for the job
If it does change then it would hve to be done on a weekend. If not then I can remove it during one of the breaks.
