VFD won’t follow speed reference input from PLC
Kcorbelli
Feb 2023
Louisiana
Working on 2 VFDs for two motors, they follow any speed command when local and in hand. Once I try to give a Speed reference from my PLC they both only go to the minimum frequencies. No matter what speed command I input. What could be causing this? VFD is PowerFlex 525 Allen Bradley
P046- 2 trm blk
P047- 3 serial/DSI (HMI)
P049- 6 4-20input
Have drawings with all VFD settings and checked in VFD itself and it matches
Are you using t062-t068 to use a digital input to select a speed reference? If not, the default (speed ref 1) will be used. In your case, that's the Serial/DSI. Is that how you're doing it? What PLC are you using?
1. Check if the VFD setting is <1 “Speed Ref 2"> on whichever of T062 - T068 selected as PLC reference.
2. Check that terminal block signal and 4-20mA current when running.
3. Check PLC program or analog module settings if no current on wire or not match expected.
4. Check wiring.
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
667
Hello, first of all let me state for the record that I'm not a tech of any kind, I have limited experience with industrial automation devices, so...
93
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
223
Customer want to use contactor for their 5HP motor blower application. im leaning to VFD. anyone use contractor for blower application...
203
82
