PLC Used in Toyota plants
hein123
Aug 2010
Uitenhage
93
Just want know which PLCs are used in Toyota plants and is it a standard worldwide.
Thought they used mitsubishi PLCs but geared yesterday they have there own type.
I once worked with a guy who was doing a project to take out some old TOYOPUC PLCs and replace them with Mitsubishi.
Not that I would know but I am pretty sure they also have some Omron and AB. Mainly Mitsubishi though.
I used to work for Automation Direct and back in those days they purchased a lot of Koyo based equipment from us but this was about 10 years ago when i was working there.
Not sure what the situation is these days.
I have actually been to Toyota City in Japan. They use mostly Mitsubishi but Toyota is not really interested in buying individual controllers. They buy the whole machine. While it is preferred Mitsubishi is on the machine it is the machine that is most important.
I was there trying to sell Toyota motion controllers. Toyota has RMCs in battery testing machines but they were integrated by a division of Parker Fluid Power. Toyota didn't seem to be interested in integrating themselves. BTW, we are a Mitsubishi alliance partner.
Toyopuc is the standard for Toyota, there are some Hybrid systems that are a combination of Toyopuc and Controllogix only because of the limitations of Toyopuc's PC3 and associated hardware.
They may buy turn-key systems with different PLC types but there standard is Toyopuc.
Has any used a ballistic pressure transducer with a PLC? I am not sure if it will capture the event that I need to use as a control. The device...
1,086
Good day all, Im just wondering if there are any existing hmi system tags that i can use as a plc input tag to indicate that there is a triggered...
1,076
I'm working on a temperature/humidity test chamber that was made in China sporting a TATO PLC that looks exactly like a Micrologix 1000. Also has...
3,286
Hi all! I have one question, it might be simple for one of you but I spent hours searching and reading through different platform until I found...
1,625
Does anyone have leads on places that will buy used functioning PLC components? Specifically Square D Sy/Max model 50 programmable controllers...
5,445
