PLC Values to PC Database
dmmons
Sep 2011
South Jersey
54
I have a project where I need to output data to a PC database (could be either Access or SAP, don't know yet) from a PLC via Ethernet.
PLC is a Compactlogix 1769-L33ER.
I was thinking of doing the following:
1) Install WinWedge Pro on the customers PC to monitor the port and move the data into the appropriate locations in the database.
2) Use an RTA 490NBX gateway between the PC and PLC to read the PLC tags and send them to the PC.
The messages would be in ASCII.
Is this a good way to do this? Is there a better way?
I don't think the 1769-L33ER has a standard RS232 serial port, just a USB port and ethernet. The USB port is used for programming. I'd seriously consider using an OPC Server.
With Ignition you could just buy the Bridge module which gives full function data connection between PLC and the db of your choice. Last time I checked it was around $2500.
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
142
I am working with beckhoff plc in twincat 3 environment. I have a array of struct which I want to make persistent. I declared it with...
111
MY PLC has only discreet inputs cards currently. Thermocouple Input card for CompactLogix is $1500 bucks and I am not sure if it is even...
3,173
I have an OPC server running that signals when a break is happening for the shift. The OPC servis and the PLC are both connected to our Ignition...
2,590
Some background: We have two assembly machines in house that make a part that gets crimped by deforming the top of a cylinder. We use a LVDT...
20
3,964
