PLC / VFD "other" applications
Horned Toad
Jan 2005
Remote West Texas
Greetings all!
I have read a good deal about PLC programming that is still way over my head, and I'm very greatful for the opportunity to benifit from the experience here at :site: . I wanted to play on this experience and contribuate a couple of things that I have come to discover for myself. First, There is no question as to the value of PLC's in automation and other compicated processes. It is becoming more frequent that I install small units to replace older technology like mechanical sequence timers, and "one off" controllers. I have found that in many instances a manufacturer will design a application specific control that is hard to find and expensive to replace. The beautiful thing about the newer "micros" is that they are generic in nature and are a plentiful, reliable, and unquestionably inexpensive alternitive!
VFD's.....At the facility where I work the majority of the machinery is non-domestic. This translates to long wait times, and considerable expense for replacement parts. One specific application uses a small gearmotor with a intergral brake. It is a 480 volt motor ( .48 kw I think )with a 480 brake mounted on the tail shaft. The brake coil on these units have rely on the motors overload protection since they are both fed from the same feed. As a result I send in a few motors to the motor shop with damaged brake coils. The OEM supplier announced that they will no longer sell coils seperately, and this application specific gearmotor is around $3K. The motor shop cannot remanufacture the coils because of careful engineering. My solution has been to toss the brakes completely and use a DIN rail mount VFD's versitility to run boththe motor and control the braking. And... I gained the ability to vary the motors speed! So in this application I chose a VFD not primarily to control a motor but more to control a brake.
I would be interested to hear of other non-typical applications for both PLC's and VFD's :confused:
The only problem I can see is that by using a vfd to simulate a brake,
you have got the control but no physical brake on the unit.
Dependant on the motor/gearbox and application you may find that a physical brake to stop movement may have been the original reason for the motor brake.
We have many applications of brake motor where I work and though in some cases a vfd would be acceptable for the motor control it would not give the assurance of the machine part not moving as a correctly fitted brake would.
One particular case is on a palletiser lift motor.
So make sure each application is looked at for not just control but also safety .
95
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
131
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
138
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
264
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
131
