PLC w/force transducer
Feb 2004
Good Morning-
Curious if anyone can provide some help -
I have a potential customer who is looking to perform tests on the sharpness of razor blades. They would like to drag a nested blade across a flat sheet of paper and measure the force required to cut through the paper to determine how sharp the blade is.
Anyone know of a PLC devvice which can zero a force transducer and perform this type of function repeatedly. They are low budget so I need to be cost sensitive. Really appreciate your insight!
John
Are you designing the mechanical aswell as the electrical?
For quick, dirty, and possibly inaccurate and buggy, I invision a blade holder on a belt drive powered by a small electric motor.
Force could acctually be calculated by using a current monitor on the motor leads. The PLC could also be programmed with a self calibration.
Just throwing the first Idea.
Tim
apply a fixed force load on the blade, and measure (using a poistioning encoder) how much travel across the paper until the blade cuts through the paper. (distance = sharpness).
I assume your test paper is on a indexing scroll. Is the paper suspended, or pulled across a flat surface? This will determine how you will detect when the paper is cut.
How do you plan on sorting good from bad?
Do they really test razor blades?
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
275
I am using Cscape 9.9 service pack 8. I am writing my program as a variable based program not register based. When I try and have the output...
846
I have a FTView ME project and i want to be able to logout the current user based on a PLC Trigger (keyswitch). How can i implement this? Is...
2,923
Hello freinds, I've a bit problem facing me with S7-200 PLC and i want to force some output values to check a motor drivers but i don't know how...
3,058
So, I've run into a bit of a difficult situation for one of my jobs. The client wants us to network the PLC (a Q PLC), the HMI (a GOT), and the...
2,112
