PLC with GSM modem how to work together ?
Robustel
Jul 2011
Guangzhou China
General PLC have ASCII string or AT command with GSM Modem work together via serial port. but likes Delta PLC just have I/O interface or Modbus. then PCL with GSM Modem how to work together?
Solution
it is necesary to have any comm port. so select plc which have facility for it.
i done it in Micrologix1400 from AB. also used panelviewplus HMI, sucsecfull.......
(y)
Remotely access plc using gsm
HELLO SANJAY,
I WANT TO COMMUNICATE PLC REMOTELY.
-ONE GSM MODEM CONNECTED WITH LAPTOP
-ONE GSM MODEM CONNECTED WITH AB PLC
-BY DOING CALL BETWEEN THESE TWO GSM WANT TO OPERATE SCADA
IF YOU HAVE ANY IDEA THEN PLEASE SHARE IT.
MY EMAIL ID IS [email protected]
Thanks...
I recently purchased a GSM modem model number SGM510 from a local dealer in Mumbai, India and I am trying to connect it to a Delta PLC that I have...
1,685
I have a task where I need to send SMS with system problems alert through PLC. I think PLC is not matter. Let's say it have RS2323 and 485 on...
2,099
Hello I am new here and came for some help. I working on project where i need to send a bit to 5 other plcs at the same time but this must be...
4,176
Hi Guys I'm a technical person who has been tasked with the job of sending sms from Omron PLC CP1E-N30DT-D to GSM Modem for alarm purposes. Now...
1,370
Can anyone help and tell me how can I read gsm modems answers? Or should I just compare response with a preset string? Thanks infront :)
1,659
