Plc
jessenette
Apr 2017
SUVA
hi.. i am new to PLC but i have a project which i use PLC with syswin 3.4 software to do my project... i need to use 1 push button to control two led (LED 1 and LED 2) or 2 output... if i pressed the push button the LED 1 will turn on but the LED 2 will be off and when i will push the same push button again then LED1 will turn off and LED 2 will turn on and when the push button is push for the 3rd time both the LED will turn off... can anyone help me with my project please if this is possible.
Welcome to the forum!
This looks like a homework assignment. Asking for help with assignments is totally OK, but nobody will do your homework for you.
I'll give you a start: search this forum (or the internet) for "flip flip" or "toggle". That should give you an idea of how to approach it.
If you can make a start - even just draw the ladder logic out by hand to get an idea of where you're going - then people here will happily give you advice and pointers.
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
48
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
39
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
80
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
180
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
55
