plc2/30 question
Ray Carroll
Nov 2005
Amory, Ms
Greetings,
I have a question about a command for the AB PLC2/30 processor. The statement "AFI", does anyone know much about it, I am in India right now, and now manuals are available. Thanks you.
Ray
AFI=always false instruction
It is often used to disable a rung for trouble shooting or project startup. I have also seen it used to disable code that was no longer needed.
If you post your questions in the "reqular" forum, you may get better responses.
Ken
HI again guys, Still converting my PLC2 project and ran into an issue with a timer. I get that the PLC2 timers Start at the 030 address and...
2,636
I am working on a conversion project to upgrade a machine's controller from a PLC2 to a CompactLogix. I know how the inputs and ouputs are...
2,669
Need some help: I have a customer with a lot of old machines, most of them PLC2s. Working just fine, no question to offer replacement yet. I must...
7,032
I am converting a PLC2 to a SLC and there is an instruction (ZCL).???? There is a Get Equal then (ZCL). What is this doing? Thanks for the help.
3,492
OK, so I have seen the threads pop up and I had been doing some research into getting over this hurdle for a bit after I ran into some of these...
878
