PLC2/30 to PLC5/20 or PLC5/11? Memory doubts?
ckchew666
Aug 2003
Malaysia
591
I've a doubts on PLC2/30 to be converted to PLC5/11 (8K) or PLC5/20(16K). I browse thru the web, found out that some PLC2/30 is 8K and some are 16K, so I wonder which one should I go for?
If PLC2/30 is 8K, can I use PLC5/11 or PLC5/20?
IF PLC2/30 is 16K, can I use PLC5/20 or PLC5/30?
The final questions is, can we use the same memory capacity as PLC2, when we convert to PLC5? I'm affraid conversion of PLC2 8K program will become 12 or 13K in PLC5 program? or vice versa?
Thanks.
Regards,
CK Chew
The question you should ask yourself is, how big is the project that I'll be converting? Check the PLC-2 memory usage and purchase the PLC-5 based on the amount of memory available.
For budgetary proposal, we need to recommend either PLC5/20 or PLC5/30 to customer before we can go on site to upload the program and check the memory usage. The rest of the I/O is remain the same, only change the CPU.
not memory but I/O
You might also want to think about the I/O size. I can't exactly remember but I believe the 2/30 had capacity of at least 8 racks of I/O. The 5/20 only has the capability of 4.
grs
It's a PLC2/30 system, besides the regular I/O, it has a 1771-VHSC, 1771-KA2, and 1771-KE. You can PM me. TIA.
1,534
I'm trying to use some old hardware - a 1771-IF analog card and a 1771-IK encoder card - with a PLC 5/60. Do these cards only work in 2 slot...
7,519
I'm attempting to convert a PLC2 program to PLC5, having trouble getting it into RSLogix 5. The 6300-um001-en-p.pdf guide does not detail this...
6,200
I am working on a PLC2 to PLC5 conversion. It appears that most everything converted ok but I am getting lost with all the math conversions. In...
7,767
Many thanks to Ron Beaufort for answering a PM for me. I am following hsi advise to post this on the forum. There is a PLC2 trainer on ebay...
7,749
