Check w/ your distributor before you buy a PCMK card; they may not support PLC-2 after Series A. Also, make sure if you have/get a Series A card that you get a Series A cable; series B cables won't work w/Series A cards.
OMG, I almost overlook this! So this means only series B will only work with PLC-2?
My own explaination is, when we need to go online with PLC-2, AI series programming software must be used. Because of this AI series does not provides drivers for PCMK series B, so we must use series A in this scenario.
Same goes to 1784-KT, we can't use KTX because AI series does not support. KTX only support in RSLinx. Correct me if I'm wrong.
AI series is using WINIntelligent / WINLinx or...?
tolong baca !
Kamu tidak bisa paket golongan kartu B dengan PLC 2 . Kamu harus membeli golongan A (yang tua) , cari di ebay - jangan campur kabel B sama Kartu A
Yes 6200 can be used....before you get too frustrated goto the AB download section. There are some tools there to help with using a PCMK on the PLC2. I believe there are also some conversion tools too. http://www.software.rockwell.com/support/download/detail.cfm?ID=98
