PLC2 Communication interface & softwares
ckchew666
Aug 2003
Malaysia
591
Anyone can let me know what is the communication interface & software to communicate with PLC 2?
Can we use 1784-PCMK?
Thx.
Correct me if i'm wrong:
The comm interface for PLC 2 is;
1) 1784-KT/KT2/KL/KTP with 1784-CP2 cable (62pins - 15pins)
2) 1784-PCMK with 1784-PCM2 cable
Software required;
1) AI-2 *
* Can only run in DOS or Win95/98 DOS mode.
I am not positive about the PLC-2, I know AB stopped supporting them several years ago. At the time they had migration tools to convert to a PLC5.
This may offer some help: http://www.ab.com/silver/plc2.html
You are correct, the PCMK and PCM/2 cable is used with the PLC-2, should have looked in my PCMK manual.
It looks like you have your facts correct.
Check w/ your distributor before you buy a PCMK card; they may not support PLC-2 after Series A. Also, make sure if you have/get a Series A card that you get a Series A cable; series B cables won't work w/Series A cards.
OMG, I almost overlook this! So this means only series B will only work with PLC-2?
My own explaination is, when we need to go online with PLC-2, AI series programming software must be used. Because of this AI series does not provides drivers for PCMK series B, so we must use series A in this scenario.
Same goes to 1784-KT, we can't use KTX because AI series does not support. KTX only support in RSLinx. Correct me if I'm wrong.
AI series is using WINIntelligent / WINLinx or...?
Can we use 6200 instead of A.I Series?
Thx for everyone's reply. :)
tolong baca !
Kamu tidak bisa paket golongan kartu B dengan PLC 2 . Kamu harus membeli golongan A (yang tua) , cari di ebay - jangan campur kabel B sama Kartu A
Yes 6200 can be used....before you get too frustrated goto the AB download section. There are some tools there to help with using a PCMK on the PLC2. I believe there are also some conversion tools too.
http://www.software.rockwell.com/support/download/detail.cfm?ID=98
Read this about series A & B PCMK, cardware, PLC2 software:
http://domino.automation.rockwell.c...06D8077C5E478F4085256AFB0067EC02?OpenDocument
Detailed PCMK info:
http://domino.automation.rockwell.c...D91CEFDC9D88668B85256AFB0061BE32?OpenDocument
PLC2 to PLC5 conversion:
http://domino.automation.rockwell.c...9AD7A2D5130BEEA485256AFB0064833C?OpenDocument
You can get a "credit" from AB thru the Step Forward program:
I have a PLC2-mini with a 1785-KA3 connected to a 1770-KF2 running software 6200. I can connect with the PLC, I can upload the program from the...
1,333
Does anyone know the pin connections for a 15 pin to 9 pin connector cable to interface between the Allen-Bradley PLC2/30 programming port and a...
3,537
Need some help: I have a customer with a lot of old machines, most of them PLC2s. Working just fine, no question to offer replacement yet. I must...
7,041
OK, so I have seen the threads pop up and I had been doing some research into getting over this hurdle for a bit after I ran into some of these...
889
Hello, I was wondering if anyone would be able to help me out; I have a PLC2 file that I can't access (I don't have the software). Would anyone...
804
