PLC3 Export error
stephenG
Jul 2007
Edmonton
I receive an "internal error" when exporting a PLC3 program from 6200 s/w. the .txt file contains 13 lines of correctly exported data until it stopped on some error. Anyone have any fixes for this?
It's been a while, I exported one and it worked fine. Usually you encounter problems with the import not the export. If you post the text file exported or the program I could give it a try.
║! ** BEGIN EXPORT ** ║
║! ** OPEN DATABASE ** ║
║! ** SAVE DATABASE ** ║
║! ** 9986 LINES WRITTEN ** ║
║! ** EXPORT COMPLETE ** ║
We are replacing a PLC3 with a new ControlLogix. There is an existing mainframe application that communicates with the PLC3 via a 1770-KF2 (DF1...
2,386
I have an iFIX system to upgrade that has and SLC504 and PLC3 on DH+. The current system uses an ABR driver and RSLinx with a KTX card. We have to...
3,330
I am working with an ancient PLC-3 and I want to set a bit based off the day (Wednesday) and time (noon) of the week. I have the following words...
5,940
It seems simple - doesn't it? :banghead: Perhaps I have been spoiled with Omron? :p A few things I must say before I pose any questions -...
17,120
I am trying to use DosBox to run AB A.I. software on a XP machine. The software runs but it can't access the activation files. Any ideas? Any...
6,827
