Using IGS (Industrial Gateway Server) with a PLC3
DHoward
Jul 2012
South Carolina
25
I have an iFIX system to upgrade that has and SLC504 and PLC3 on DH+. The current system uses an ABR driver and RSLinx with a KTX card. We have to get rid of the KTX and would like to use an ethernet gateway to DH+. RSLinx configures fine with the gateway, and I have been able to bench test comms to an SLC 5/04 over (Ethernet to DH+) and it seems to work fine (The IGS is using the Allen-Bradley Ethernet driver with the gateway IP and the SLC DH+ station address). I don't have a PLC3 to test with before attempting to startup in plant. Does anyone know if the IGS set up with Allen-Bradley ethernet (PLC5 family) will work with a PLC3? Difference in I/O addressing being I0:2/0 vs I:0/2, etc. Any help or suggestions would be appreciated. If the IGS and gateway will not work, could I use the AB USB to DH+ converter and just keep the ABR driver in iFIX intact? Thanks
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
36
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
70
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
131
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
229
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
77
