PLC5/40 to 1746-NI8 Class 3 via 1747-ASB
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Why does RSLogix5 allow you to choose the 1746-NI8 Class 3 Mode, and insert the correct size BTR/BTW rungs even though this mode appears to be unsupported? Is it only supported over ControlNet?
The card is in a RIO Rack from Channel 2B of the PLC5 with a 1747-ASB in the remote rack.
Or did I mis a step in configuring it. I switched to Class 1 mode and re-used the wizard to create rungs that work (I had to delete the card and I/O points first).
I already rolled my own status bit logic, but if Class 3 mode can be used remotely in this setup, please let me know.
Thanks,
Paul
Paul, I may confirm the module can only be used in Class 1 mode over RIO... it has been confirmed to be an "anomaly" inside RSLogix5 editor.
- fuzzy logic
Maybe someone in this forum has encountered this and could offer some suggestion. We connected a 1746-NI4 via 1747-ASB to a PLC5/80 on Ch1B...
5,478
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
161
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
379
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
532
