Hopefully this is fairly clear cut. I need to get a 4-20mA signal added to an I/O module of a PLC5 40 E. Using RSLogix5. There already is an identical input setup at a different physical location (pond level). I am just getting the reading added to the PLC so I can create it's field in HMI for operators. The backplane has 17 slots, two analog inputs and 2 analog outputs. The analog input modules have wires terminated on every channel. But I see two wires I know are inputs terminated onto the analog output modules where there are open channels remaining.
Basically I just need a little guidance on 1.)if I can terminate input to an output card? It doesn't seem logical, but it appears like it's being done.
2.)Once I get the input physically created, how do I find the internal address to create the HMI link? Is it in data tables? Will making the physical connections, then power cycling the backplane auto read the new channels on the module?
That's it for now. I'm sure I'll have more questions as I dive into this. I was trained on Contrologix and this is a bit different than that. Any info/guidance is very appreciated!
Thanks!
Thanks!
