PLC5-CLX ethernet question
alan_505
Feb 2007
Melbourne,Victoria,Australia
1,045
Does anyone know if you can connect the pins from a 1756-EN2T RJ45 plug to the 15 pin transceiver that was previously connected to a PLC5/40E AUI port, if so which pins do I connect to.
Alan
Thanks for the prompt reply, I was afraid that would be the answer, just wanted it confirmed.
Alan
What I am trying to do is connect the 1756-EN2T to the original transceiver that was on the PLC5.
It is a 3Com ISOLAN 1680-5.
Trying not have to use a RJ45 ethernet to fibreoptic cable, all the AB stuff has LC connectors and the 1680-5 is connected to the plant fibreoptic network with St plugs.
You should be able to pick up an AUI to 10Base-T transceiver for about $20 to $30 US. You are going to need a switch also if you want to use the Ethernet for anything else
Our client has a PLC5/30 series C processor and the job requirement is to provide Ethernet comms to an L61 CLX processor. The client doesn't want...
3,937
Hey fellas, I did a search but didn't find anything that quite fit. I'm setting up a new CLX chassis (with processor) for a new project. I need...
5,543
I've got some code running on a Compact Logix/Control Logix using CIP Generic Message instructions. Service Type is Custom Service Code is 45...
22
5,754
I have a CLX processor with a 1756-ENET connected to a CLX gateway that has a 1756-ENET and a 1756-DHRIO. On the DH+ side I have a PLC 5/30. I...
8,188
The attached files shows a rung modified by the Migration Tool. Can anyone explain the purpose of the added parallel branch? I figure it has to do...
1,758
