PLC5 DNet Module
WTFSUNELECSUP
Jan 2014
Alberta
63
What are the major differences between an a Allen Bradley 1771-SDN Firmware B card , and Firmware C cards. We have currently have Series C firmware Rev 6.002 and 6.005 cards, and I'm trying to find a replacement but can only find a Series B.
The cards control an Ultra 3K drive, over Dnet.
Series C was a hardware, memory, and firmware upgrade for the 1771-SDN, which added Auto-Device Replace and Slave Mode functions to the module.
If you are using those functions, you need a Series C module. Otherwise, a Series A or B module should function identically.
Series B can't be upgraded past version 5.x, and you probably cannot load a Scanlist Configuration from a Series C (6.x or later) into a Series B scanner. To use one as a spare, you'll have to reconfigure the scanlist for it manually.
I checked the RA Knowledgebase and found that they've discontinued production of the 1771-SDN as of the end of December 2013.
Thanks,
I found out last week they had discontinued the production, and I'm currently trying to buy a used spare from a electronics repair center.
Hi Everyone, I’m looking for some help. My boss decided that since I’ve seen a PLC once that I can just jump in on any PLC and figure it...
3,126
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
154
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
373
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
521
