PLC5 encoder card addressing
alebdun2000
Jun 2012
Vaughan
Hi ,
We have PLC 5 and encoder cards in first three slots.since I used to work only with SLC500 and 5000 there was easy concerning addressing and using encoder value in program, encoder card only as input and output for devises from normal output cars but here on PLC5 encoder card has its own outputs and I can't find them in program . Any rules how to refer terminal on output of a card with N file ? Thank you guys for help
Welcome to the Forum !
PLC-5 specialty cards use Block Transfer instructions (BTR and BTW) to read and write data to and from Integer data files in the controller.
If this is an existing system, you need to look for those instructions that are addressed to the Rack/Group/Slot location of those modules.
The 1771-VHSC was the most common "encoder" module for the PLC-5 but there are others. Determine the type of card you have, and you can get the User Manual from the RA server at http://literature.rockwellautomation.com.
I have an application that uses a 1771 VHSC card, 845T incremental encoder using differential line driver with a 5 volt supply, and 150ft of...
3,300
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
158
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
373
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
524
