PLC5 'Slot Addressing'
Thanks Jeff, thanks Jesper.
Jeff, as Jesper assumed, I was not planning to have any outputs connected to the output card, or initially any inputs connected to the input card.
Regarding the Input Image Table, are you suggesting that this may have data (from some other source) that will be overwritten when the additional input card is seen during the input image update?
I am less experienced but I do believe a programmer could use the data tables for unused slots as internal bits. not necessarily common but still possible
rlmts,
just seen your thread, and to catch up, I am quick-reading all the posts, and I see that you included an image of the I/O configuration (untitled6.jpg), which shows all the Chassis connected to the PLC.
If you double click on the chassis number, then it should expand to show the cards and slots allocated to that chassis, if the programmer has added that detail - and having gone to the first stage, then I would hope they have added the extra detail. That will at least confirm the installed modules.
Hi John,
Thanks for the input, I don't have the PLC programme with me at the moment so I'll check this out when I am back on site.
But I believe the extra detail is not there :(
Hi All, I am looking at a future project that includes a PLC5 with some digital I/O. Its been a long time since I have worked on the PLC5...
1,618
Hi all, I am currently working on a project to convert three PLC5's to CLX using the Rockwell migration tools. I was wondering if it were...
16
9,958
Hi Friends, I'm to swap a few Digital Outputs (XV) from their slot to a different slot. The Processor is a PLC5/30 (Ethernet). I'm more familiar...
2,213
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
191
