Mark Snodgrass
We have a Power-flex 700 drive with a 20-comm-e communications adapter card being commanded from a PLC5/40E. The communications work fine during normal operations, the problem occurs when the ethernet cable is unplugged, power is cycled on the drive, or a power outage (anyone have a 100MVA UPS? ).
The messaging errors out for up to 15 min before it starts talking normally. Thankfully this is not a critical motor, but we want to be able to convert our other drives to ethernet communications and are hesitant to do so till this problem is resolved.
I have tried talking to AB tech help and they did not have an answer.
I have looked on the adapters webpage and I can see it is receiving and sending. I can also connect with Drive Executive and see the drive parameters, so I know the ethernet connection is good.
Has anyone else had a similar problem, and were you able to find an answer?
Thanks in advance
Mark
Thanks in advance
Mark
