jtn
Give this a look.
http://www.prosoft-technology.com/content/view/full/10951
Maybe that is what you are looking for?
danw said:I sat through some Codesys overview training last week.
The statement was made that Codesys has an OPC server embedded in it, so those hardware targets that run a Codesys compiled binary have an OPC server as part of the configuration. The Codesys web site confirms that
http://www.3s-software.com/index.shtml?en_OPC&sitesearchmatch=opc#sitesearchmatch
Note the claim:
The CoDeSys OPC-Server V2.0 is able to communicate with all controllers programmed with CoDeSys. It complies with the requirements of the OPC standard V2.0.
I pressed the issue by asking whether or not an OPC server was a licensed run time extra, and the claim was that it is not.
I think Beckhoff uses Codesys as its development platform/runtime software, does it not? If so, it might place in this category.
If the Codesys statement is true, then the spec could be a lock-out spec.
Dan
Hi Jesper ,It is indeed not clear at all, but I interpret it as that the OPC UA Server connects to the Beckhoff PLC and Serves the data from there to other devices.
The OPC UA Server comes in two versions for Windows and Windows CE, and I think they are intended to be installed on the same Windows or Windows CE device where TwinCat resides.
It was released just recently, so there is not so much information about it, no manual for example.
