PLCs and stepper motors
Jon R
Jan 2007
Tadley
206
I am trying to figure out a way to use stepper motors to adjust the angle of an HMI screen mounted in a box on the desk.
I am using a Twido PLC, and could do the code, but I have no knowledge of stepper motors. Is this the best way to go? What hardware would I need to control it.
Regards,
Jon.
Stepper Motors
Try these people. Their products are very well priced. You will need a motor and driver that will accept a high frequency pulse (step) signal and a direction signal. I have used one of their small drivers with a Mits plc. You will need transistor outputs on your plc. If they are 24V then you will need a resistor in series with the input to the driver to limit the current, other wise you could use 5V on the common of yout pulse output and direction signal.
They have a linear stepper motor that you may be able to use to push and pull the screen if it is hinged at the top.
http://www.motioncontrolproducts.co.uk
I have found them to be helpful.
Stepmotor (especially on lower rpm) is a source of severe vibration which may harm your HMI.
On the other hand, it looks overkill for the application as it may cost along with the drive more than the HMI itself.
I would consider subfractional DC gearmotor.
i think
dear
do u have stepper motor if not arrange it actually to run stepper motor we have to give digital coads to it we you buy stepper motor with cataloge it is mentioned what is its step combination coad mostly stepper motors need 4 bit , 0ne byte combination . you just have to programe that coads in your plc according to your requirment and if their is differnce b/w plc out put and motor input you can use any thing that is available in your site
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
18
303
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
113
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
319
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
196
