PLC's, power supplies, and wireing
JOLTRON said:
What do you mean 0 to -24vdc??? I don't understand how you can get -24 volts.
Take any two batteries of any equal voltage. Wire them in series additive. In the series connection between the two hook up a test lead. Read to the opposite terminal of each battery. You will get + X volts on one and - X volts on the other.
The series connection between the two batteries could be used as a common.
In the days of tube electronics these were called B+ and B-
Dan Bentler
keithkyll said:
Sounds like more of a trick question than anything else. Two 24DC supplies, but one of them has + as the common. That's the only way you could get 48DC on the input.
PLC1 has relay output and soucing the -. +24 is wired to common return.
PLC2 has sinking inputs. -24DC is wired to common return (shared between the 2 supplies), and +24DC is wired to input common.
Does anybody tie +24 to ground? I don't think so.
You would be surprised! I have seen lots of Japanese machinery that has all the +24 tied to ground! ...and their drawings are
backwards
Some PLC manufacturers sell power supplies that attach to the left of the PLC CPU modules (see controllogix and automation direct click's PLC)...
2,216
Hello everyone, I have a PLC question, in regards to using several external 24 VDC power supplies, from different machines ! I only have (2)...
3,547
Here is a newbie question. Are DC power supplies used for any reason in the industries that use PLCs? This is not including any PLCs themselves...
3,735
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
143
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
