plcs7-300 and absolute encoder
seee
Dec 2010
singapor
112
hello.
dear friends i am studying plc s7-300 and i need a program
that read absolute encoder value on profibus.
i have searched on google but i coulden't find any program.
manufacture doesn't matter but it was absolute profibus encoder. please help me.
best regards.
thanks a lot for your reply.
i need just a plc program in which an profibus absolute encoder
value is read.
in this forum no one have used absolute encoder before in a project!
best regards.
value is read.
best regards.
o_O If you don't give specific info, the answers you get will be unreliabe also. And that is not very well liked here.
Here's my best guess of what you want:
If you assign the profi address in the process image area (say below IO byte 128), you can, independent how the consistency is set, read the double integer value like this:
L IDx // 0<= x <= 124
Note that there can be several settings to select the mode, sw gate, counter preset, and so on.
Kalle
hi guys 👨🏻‍🏫 I have cpu 313c-2dp and MM440 , I downloaded an example from http://support.automation.siemens.com/WW/view/en/22078757 I tryed...
6,133
63
165
Hi i using Kinetik 300 2097 driver control by EIP with using move absolute and incremental for motion , but i want to add same driver and motor as...
59
48
