soop7667
Without a very good understanding of Math Overflow - I just put my math logic into the PLC without it - I also considered the fact that it's physically impossible to run one of our Concrete Products Machines more than 10,000 Cycles in 1 day let alone 32,767. I just want to get the ball rolling anyways - I can always put that in later when I fully grasp how to validate it. So now I have 2 more rungs - one of which Multiplies the Thousands Count of each machines cycles Times 1000 and Latches a BIT which denotes that the Values have been multiplied. Then as long as that 'Multiplied' bit is energized - The Second new rung Adds the Hundreds Count of each machine to their respective Multiplied Thousands Count. The Destinations are N7:40 (Machine #1 Finished Cycle Count) and N7:50(Machine #2 Finished Cycle Count) After the Hundreds have been added to the Thousands I Latch another Bit which Denotes that The Addition Has been Executed - That Bit prevents the Addition from happening again until it is unlatched when the Multiply Rung Executes.
Now I need to Store N7:40 and N7:50 Into two different Files and Index the address each minute when I plug a new value in. (This is what I really need some help on.) Indirect Addressing I believe Is the way to go.
