Please Help
don5mile
Sep 2010
Arkasas
I am new to PLC's and I am trying to get a stepper motor to run off of my Click. I have a 5v driver and a 5 wire stepper. They both work I can get them to run together when they are not on the PLC, but I am having problems wire them to the Click and getting them to run. Please help
So, let's start from beginning.
First, i don't know which plc you are using. But doesn't matter
as it follow IEC programming standard.
So, figure it out the rating of motor.
Then, go for function block in progrmamming enviroments and give
input and output. Like, you can find Function_Move,Function_stop etc.
Make your system configuration perfectly.
You should give try because you didn't provide enough information like which PLC or which motor you are using.
Define steps of motor and calculate and programme it accordingly.
I hope it will help.
I think the wiring is the first problem to tackle. So can you post how you have wired the stuff together?
If the wiring is OK and the stepper still won't run, then we can get a look at the code.
Regards,
please help me . I have to make this ladder diagram and I can’t figure it out :(
433
101
Hello, I am trying to get a Yokogawa Hart pressure Transmitter and a Rosemount Temp Transmitter to read on a 1769-IF4 module on an L33ERM...
415
Please help me, I have solve many week but still not solve it. I found trouble of factory talk studio when I set tag by browse address of OPC...
144
Hello Everyone, i Have im my Industry a Endress & Hauser Promag400 this has a screen that constantly have that error, it says to wait, somebody...
516
