PM5563 Schneider (sq D) power monitor
remullis
Oct 2012
Georgia
179
Has anyone had success mapping the PM5563 to controllogix. I am able to get information from the unit to the plc but I don't know the actual mapping and what is needed to manipulate the data. I have had no luck with Schneider on this one.
RM
RM
What do you mean mapping, do you mean from PLC to Contrologix ?
The PM5xxx Modbus register list is publicly available:
https://www.schneider-electric.co.uk/en/faqs/FA234017/
I am not familiar with Contrologix but if you have it at the PLC it shouldn't be much of a task to get it right ?
I just realized this register list is for Modbus. I am communicating through E/IP. Anyone have anything on this protocol.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
48
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
142
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
71
123
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
201
