Pneumatic to servo feed
Skiroy
Mar 2012
Panama City,fl
199
We have a machine that uses a SLC500 and a Air Cylinder to feed pipe through a cutter to certain lengths. We have talked about converting to a Servo motor for better accuracy. My boss told me they were quoted $25000.00 to do this. I would like to look into seeing what it would take to do this myself. I obviously would have to figure out how to integrate the servo into the PLC program but for now I need to find the correct motor and drive.
I know he told me the company that came and quoted him the cost of the conversion set up equipment and said he would need a motor capable of push 400lb.
Can anyone give any insight on where to go from here as far as motor selection?
I suggest you google for a servo actuator - something with a integrated controller/drive that has simple I/O interface that you can connect to your SLC system. You didn't say how many different lengths you need so that will be important in your consideration. Tolomatic is where I would start.
you could use a endplate with a small motor and a long bolt. this to set where the cylinder should stop. As the motor is not running all the time it can be very small.
accuracy is below 1% (i used to work for a company making copper tubes.
I have an actuator operating a clamp that requires PLd/SIL3, I’ve seen some SMC double valves with feedback, but they are described as dump...
2,368
Dear experts, i have pretty basic/ dump question, can someone help me to figure out how to read/ what is this? i assume it is solenoid vavle...
1,064
If anyone has any information on how this sensor operates or has one they would be willing to sell, need it ASAP. Old machine is down because of...
1,138
I am looking for different solution on controlling a pneumatic Cylinder move at preset positions. One of the solutions is to use 5 magnetic...
22
5,992
3,851
