Do you mean you have a pointer to an array of chars stored in a DB and that the pointer is passed to a function and you want to process the array of chars in the function ?
The variable name is ch_ar and it is an array of bytes, not chars. The four bytes at DB1.DBD2 contain an area pointer so to access the data you load the area pointer into an address register and then access the data.
