Hello everybody!
I have a question regarding pointers in step7...
As far as I see this is some of the harder things to understand using the S7 plc's. I've been reading the Siemens help on "pointers" and "any" and I've been using dynamic "pointers" (buildt my own) in the past. So I know what to put in what byte and so on to make it work. But I'm still confused about what to use when. Like what is the real difference between "any" and "pointer" and when to use them? Usually I use "any" but...??? Ah... just confused!
Also according to the Siemens help file I can add a number to the AR1 using the +AR1 command, but what does this do? How can I use it? Will it change the byte address or will it change the bit number..
So input would be helpful.
Regards
Borte
Regards
Borte
