Pointers in Step7
Terra70
Nov 2006
Westcoast
Is it not possible to use pointers to "TEMP" variables inside a FB or FC?
When the variable("SomeDWord" in the example) is located in the "STAT" folder inside a FB it is working, but when the variable is located inside the "TEMP" folder nothing is happening....
LAR1 P##SomeDWord
A DIX [AR1,P#0.7]
S DIX [AR1,P#1.3]
Note that DIX refers to the currently open instance data block. If you want to refer to local data then use:
A [AR1,P#0.7]
S [AR1,P#1.3)
as the LAR1 p##SomeDWord will have set AR1 to point to the local area.
Hi every one. I am trying to verify the following: A DINT can be converted to a POINTER by simply shifting the double word left by 3 bits. i want...
2,081
Hello, I try to understand a function block where a string is copied from an address (source) to another address (destination) by using...
7,483
Hello, I've just came out of a call where a program that was modified two weeks ago threw the processor into fault. The program has been done...
3,470
I'm trying to get a 5069-L306er to talk to a Automation Direct ProSence Controller by using RA's AOI for modbus client but its stuck not getting a...
1,881
The last time I did anything with Wonderware was just after the dot com bust. Boy, I feel old. Anyway, it looks like I will get the chance to...
1,518
